RipperXX
- 5,788
- 172
- Feb 23, 2003
Royston,
Georgia
Theres a decent possibility I have a bent valve, im thinking on the #1 cyl since the plugs out it are a little funky.
Would you drive on it if it was that or a MKIII Supra you dont quite trust yet with a huge boost leak that drinks gas worse than any V8 I have ever seen.?
BTW just changed T-belt and I think there could be some vacume/boost leaks so im not ruleing anything out just yet...
) well anyways what happend to me when i had the valve problem was that when i came to a stop from like going 20mph to slow down to catch a stop sign it would stall out....i had tons of smoke out my exhaust...serious blowby....but yea the stalling and rough rough idle was...really really bad... prob not as serious as ur would be due to the fact i have prob like 8 more bent valves then u...which means that my compression is even worse.....but now 1mm os valves nitrated coated should do jus swell...
