Drill and tap exhaust manifold
Paddocklke1
Apr 7, 2005
Paddock Lake, Wisconsin
I have the Exhaust manifold from the G4CN and it is good shape however, it is not drilled and tapped for an O2 sensor. Can it be tapped by my self, I don't own a shop and am trying to do this cheap...
I ask because the NT manifold I started with is cracked badly.
Thanks,
Joe
You need to drill and weld on a bung for the o2 sensor. If you just tap the manifold, the heat expansion and contraction will gauge cracking and improper fitment.
That is a good idea, I do have a bung already. Now to fix the damaged flex sction of the pipe or replace it. I should have thought of that:coy:
Need to check my other post regarding that.
Thanks again,
Joe
Quick follow-up question:
Would it be too far away or can I weld the bung onto the Intermediate/downpipe that is connected to the exhaust manifold?
Thanks again,
Joe
It is not a wide band, the placement question is because this Hyundai exhaust manifold I'd like to use does not have a tapped O2 location.
The NT 4g63 manifold I am using now is badly cracked.
The front 02 sensor needs to be within 12-14" inches of the head
