Drifting DSM?
And FYI a rear solid axle is Not the best for drifting, an independent rear with adjustable camber (Rucas) are the ideal set up...
It's your car. Do what you want with it. Here's some inspiration for you:
BTW, leave stubs in the transmission so you don't lose your gear oil, and leave stubs in the hub assembly so you don't ruin your bearings.
turbDSM said:
The bearings your talking about are pressed into the steering knuckle. thats the hub assembly. The drive axle goes threw that hub assembly. In broad terms it will pull out like a driveshaft. It isnt that easy though. Its different for each side. Im just sayin that it can be done.
No offense but duh!. Turbo DSM I happen to be an ASE CERTIFIED MECHANIC who has been working in garages for 12 years. I was just pointing out that if you just remove the front axle shafts the pressed in bearings( which are called unitized bearings) would separate and the wheel would basically fall off. No offense
Rice Over Wheat said:
What ignorance. Professional drifting is controlled mayhem and takes great driving skills. Try watching a professional drifting team running a track in perfect unison 3 cars side by side.
Plenty could argue that drag racing is one of the most primitive forms of racing...light is green and you go forward. Wow!! :rolleyes:
And plenty of domestic drag queens think musclecar drag racing is "sacred" and no place for imports. They're also jackasses.
To OP...get yourself a 240 and do a jdm conversion. One of the best drift cars there are and they are cheap and easy to work on.
blahhh to the 240 what happened to the SR5 corolla coupe of the 80's ?mmmmmmmmmmm :D
Why is there so much attitude in this thread? Leave the bullshit behind and keep it on topic.
Well aren't we Mr. Proud. I'm ASE certified in 15 different area's and you don't hear me bragging it up on here telling people that because I'm ASE certified I know more than you. If he wants to try to drift a DSM let him go for it. I would make sure you have a 4 bolt underneither there and upgrade your rear axle's and check for play in your rear end gears to see if they need attention before you put 100% power to them.
  • Wanted 6 bolt NT water pipe
    • chrisman287
