Drag Radials
97 gst turbooo
132
Aug 26, 2006
Lowell, Massachusetts
ive read about running drag radials on my 2g gst and more people have pushed further to running slicks than drag radials. I was looking more towards running either 225/50/16 hoosier dot drag radials or maybe running the gforce r1 radials on my stock size 205/55/16 or a 225/50/16 on my stock gst wheels. i havent found much help on a good slick size. Im thinkin 15x8 rota's on a 24'' slick
If you do some looking around here you'll find lots of good info on both drag radials & slicks. My track tire choice was very limited because of my Wilwood brakes, so I will be giving the Hoosier Drag Radials a shot in the 225/50/16 size. If you go with any drag radial, defently don't go any narrower then 225. If running a 15" rim was an option for me, I'd defently go slicks if your looking for a track only tire. Their easier on the drivetrain & most of the time will hook better. Around 24.5" tall is what you'll be after, believe M+H has one in this size. Here's a link to the thread I started on drag radials & shows my setup:
http://www.dsmtuners.com/forums/drag-strip/271320-bfg-vs-hoosier-drs-fwd.html
