Door lock question
kt239
192
May 15, 2011
Pittsburgh, Pennsylvania
I am installing a remote start on my talon and was testing my wires for the door locks and it seems only the passenger door responds to the negative pulse I'm sending. Is this a normal response? Also when I use to press the lock on the driver door it would lock the passenger door but it's no longer doing that. Any ideas?
You might need to take the door panel off and inside there's a white piece. This is for the door locks take the I believe 6 screws out and clean all the points off inside and maybe a little dielectric grease after. Reassemble and it should work again, mine gave me the same kind of problems. Once I cleaned the assembly good, its been working flawless ever since.
Well thank you for the input I'll give that a shot.. The panel is already off and I see what your talking about but only see 3 torx heads on the outside securing it.
