Done, and now some questions
Boma
61
Jun 14, 2009
Reseda, California
I bought an AWD over a year ago and with the help of this forum, I am now ready to make power. I will try and keep this short as much as I can.
This car was originally bought as an ATX, now I dunno if the small turbo and small injectors also apply with the AWD platform as I know that ATX 1g turbo cars differ from the 5-speed in terms of this. 2 months ago, it was then converted into a 5-speed along with a spec clutch and lightened flywheel. Now here's the question:
Do I need a 1g ECU from a 5-speed car and does it necessarily have to be from a AWD?
Next, the car's engine has been rebuilt 8 months after I got it. I followed the tech guide article and pretty much started on replacing parts that I wasn't sure if it was taken care of so the last thing I did was rebuilt the engine. It was pretty much a stock rebuild except for the wiseco 9.0:1 forged pistons and ARP head studs with MLS head gasket. I've already set my goal at this point. Here's the stuff that I got that's going into the car:
- e316g + O2 housing
- evo 8 560cc injectors
- e3 exhaust manifold
- necessary gauges (EGT, boost, A/F and/or wideband O2)
- MBC
- FMIC (still debating which one I should get)
- RRE magnus intake manifold (optional?----need feedback, guys)
And here's the conflict, what is more efficient at this point, getting a MAF-T or going for a S-AFC II with a 2g MAF?
Last, as I said earlier, I've already set my goal, I don't really care at this point at how much HP the car makes to the wheels, I just don't want the hassle of tuning it to the point that I'm gonna get obsessed. So now, a 190 lph fuel pump is going in along with the rewire. Last question:
I don't want to use an AFPR, so is the 190lph good enough not to be tinkered with?
I've spent $900 for the 5-speed conversion and $1500 for the rebuild, as for the bolt-on parts, close to 2k. Not counting the maintenance after getting the car.
Thanks in advance
-Boma
As I have read on this very forum, on a MTX the ECU is tuned for a TD05H 16g IIRC with 450cc injectors. Whereas the ATX have a smaller turbo and injectors. So it will still run your car but slightly off.
The rest of that I'll let the vets take care of.
So even the AWD with an AT transmission gets to be punished by the puny 13g and booger-flowed injectors. This sucks. So now I have to massacre a DSM junkyard to find a 5-speed ECU, I just hope it doesn't have to be from an AWD. Thanks for confirming this. I appreciate it.
