Spyder DOHC head swap onto 4g64 Spyder!!!! Almost done!
droppedspyder
38
May 12, 2002
Pocatello, Idaho
Got my head ripped off last night, put the freeze plugs in, and the mocked up my head with turbo on it. Looks like a million bucks!! I still need to put on the head gasket, and install my new 4g64 DOHC timing belt. I will post pics later. The only problems I have ran into is getting my intercooler modded to fit, run a resistor pack to my injectors (will be done tonight) and run my Camshaft Position Sensor,using my CAS and just hard wiring it together. It has been pretty easy. I am just using a stock t25 for right now, but I plan on upgrading to a small 16g possibly. The parts I am using that are aftermarket are as follows, an HKS SSBOV, Injen Intake Pipe, Civic CRX Resistor pack, Walboro Fuel pump, Cometic Head Gasket, and possibly if I can find a cheap one an AEM or B&M Fuel Pressure regulator. If you have any questions feel free to email me at [email protected]
lemme know the approximate cost jus to do the dohc conversion without the turbo.. and how hard it was.. thanx
