does this look ported already?
talon_frost
194
Feb 10, 2008
Kitchener,
was gonna port my turbo but by the looks of it, someone else beat me to it ?? am i right?
well now im kinda stuck ### the point was to port the turbo so that the boost creep would leave a bit, maybe something else is the problem, i put that little restricter in the vac line off the turbo outlet right before my boost controller....could that be the reason for the creep?
That's not much porting at all. That looks very minimal infact.
If you're trying to get rid of creep, I think that's what you meant, then port the wastegate area out more.
Make sure to remind people they must port the housing too the wastegate port and not past it. You want to keep that bottom lip at the wastegate hole to catch the air and let go though the wastegate. If you look at the left side compared to the wastegate side its a lot different, there was some good porting done. Usually you cant even see the wastegate hole because of the huge step in the way.
In other words:
Porting: Removing matter from the casting to direct flow of air.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
