does anybody run a little hot when blasting the ac?
ryu
489
Feb 6, 2003
never never land, Maryland
well this is my first summer with my car and i noticed today that it was running alittle hot. it was a quarter inch above the middle. my ac was blasting and i was stuck in traffic. after i noticed it was a little high i turned the ac off and it went almost back to the middle after another 10min of driving. :confused:
its normal it should go back down when u drive also w/ the ac....its tipical for ur car to heat up while sitting in traffic w/ it blasting
usually when the ac is on the car will start to overheat and that is not a good thing for your car, so i would definitely watch that and if you are gonna use any ac at all keep it on the lowest level so you dont risk the chance of overheating. I put it on the 3rd level once and after like 5 min it started to over heat, turned it off and it settled right back down. I prefer to just not use ac at all that way i dont run the risk of overheating and i also dont rob any power from my car.
