2G Does a car need both o2 sensors to pass emissions
shaunp
115
4
Mar 11, 2008
Snellville, Georgia
Hi All,
I've searched and cannot find a straight forward answer for my situation.
I have a 98 GSX, the car has ecmlink v3 and an AEM wideband. I do not have any factory o2 sensors. I need two readiness monitors to be complete in order to pass emissions.
I've attached two screen shots of my current settings in ecmlink. Is this correct? Are there any other settings I need to look at? My wideband is in the rear o2 sensor bung.
The car threw 2 DTC's (P0136,P0141) heater circuit malfunction.
Is there a way set the readiness monitors to complete with my current setup or will I need to buy both front and rear o2 sensors?
Thanks,
Shaun
Yes, both sensors need to work to pass emissions, a 98' could technically be flashed with Ceddymods and the readiness set to ready full time if you wanted to.
Worst thing that'll happen short term is you'll probably get bad fuel mileage. Long term, oh yeah it'll definitely ruin your cat. Which can get real expensive real quick. your car also won't pass an emissions test, If you have them in your area. Just replace the O2 they're cheap and pretty easy to do on your own Kodi nox.
