95GSXCO
- 268
- 0
- Mar 15, 2006
Sterling,
Colorado
Iam having a knock sound around 3000 rpms. I lifted the car up and had the wife rev it a couple of times and it sounded worst under the car. I thought maybe the flywheel bolts might be loose. Which was not a big deal because I had a new clutch to install. Well needless to say it was not them, So I jump on the forums start reading about the tensioner might be making the nosie. I crack it open today to see this when its reving but whats odd is the knock is no longer there? One more thing is I noticed that the crank sprocket has a chipped tooth on it where a bolt goes! So I have a 6 bolt just sitting doing nothing is the crank sprocket the same for the 6 and 7?
Sorry about the vid it was taken on my Blackberry.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/UZFP2xQLoEU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/UZFP2xQLoEU&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
. Iam really starting to think its a rod bearing going out! The thing that gets me is that when you drive it at about 3000 RPM + it will knock like a rod going out and when you free rev it its alot harder to hear? Do you guys really think that the pulley can take out a rod bearing? Every time I have heard bearings going out its anytime the motor is running but I guess it will just get worst as time goes on till its knocking all the time. Would you guys suggest replacing the mains also? This motor has maybe 2500-3000 miles on it.
WTF
