Do I need an FPR? Other suggestions?
dsmchiz
40
Feb 27, 2006
denver, Colorado
i have had my dsm for 3 years and have read lots about my car and done a bit to my car. this is what i have done to my car so far
Bolt Ons:
GM maf translator 3" Mas Air Sensor,
Small 16G turbo, ported by Forced Performance,
50mm tial bov,
Forced Performance ported exhman and O2 housing,
Clutch Net 2600lb plate
6puck clutch
New '94 spec transmission,
Accel 8.5mm Wires,
3" Bud's custom "turbo-back" Exhaust (no cat),
Hallman Manual Boost controller at 16psi,
Wallbero 255,
APEXi Super AFC (Air Flow Control),
RC 550cc Fuel Injectors,
HKS Fuel Cut Defencer,
Buschur Front Mount Intercooler
Denso Radiator with 2 12" slim line fans
Engine Mods:
Block bored .5mm over,
Cylinders honed with torque plate,
'95 Pistons .5mm oversize,
ARP Head studs and rod bolts,
Balance shafts eliminated,
Bowl blend on intake valves,
Mild porting on intake and exhaust ports,
Intake valves backcut,
3 angle cut on valve seats,
Cylinder head de-burred,
Upgraded Valve Lifters,
Hks 264 cams AEM Cam Gears,
Hks valve springs
just bought not installed yet:
Magnus Manifold w/ velocity stacks, Clutch Net 2600lb plate and
6puck clutch, and aeromative fuel pressure regulator with ss lines and gauge
When i went to the track last year was having phantom knock issues (still ran 13.1)so i got the new knock sensor and colder plugs (ngk bpr7es, which i will be putting in when i put in the new clutch, manifold and pressure regulator)
i just read yesterday that my issue with tunning my car could be that i did not have a fuel pressure regulator. i have not been able to get a stable tune (been using egt, wideband and jumptronix voltmeter for o2 voltage) . do yall have any other suggestions. when i was logging it i had 0-1 points of knock until 4700 rpms then it just spiked phantom knock and pulled timing out. i have checked and i have no boost leaks. i will be putting all those parts on sometime in the near future so i figured if there was something else i could do that could fix the problem i would do it at the same time i had everything else pulled. i appreciate yalls time.
thanks again
chad
You've got to get a FPR on there. It does explain your inability to tune. Your flow rates keep fluctuating with your pressure since the stock FPR can't handle the 255. I'm not saying it will solve all your problems for certain, but it will help.
Yea see thats exactly what i was thinking when i was reading posts yesterday. Its like one day wow the car runs great then the next its like i have to tune all over again. Kinda gets annoying after awhile.
