DIY Strut Bar for 2G
pointblank9957
284
10
Jul 12, 2012
Sheboygan, Wisconsin
I'm heading to Tractor Supply tomorrow to get a 2"x.5"x48" bar of Aluminum to make a strut bar for my Spyder. Will .5" be thick enough or should i go with .375"(3/8")? Or should i go .75"?
EDIT: i finished up the bar and i think it turned out pretty well! i used aluminum tubing instead of a bar, and i used angle iron to mount it to the towers. by the way no that is not anodized, i just polished the aluminum and used Candy Red paint on it.
i noticed a big difference when hitting bumps and going over railroad tracks! it doesnt shake as much going over the, tires dont squeal as much when cornering and the body doesnt roll as much on tight turns
pics:
This shouldn't fix body roll.. It should just fix flex in the frame, or make it more predictable (less sloppy) over bumps and such. Get coil overs and sway bars for the roll.
Make your own, concentrate more on your mounting to the towers than the bar itself, the bar will be both under tension and commpresion put some heim joints at the ends and you will be looking good.
Can you explain in more detail how you mounted it?
I have a strut bar with no tower mounts and apparently nobody sells just the mounts.
On the tower there are 3 bolts that hold the plate on the strut, i took the ones towards the front off and and bolted the angle iron down under the nut, the angle iron is pointed up at a 30° angle and bent back so its perfectly level, same on the other side, then the bar is just bolted front to back with 1/4" bolts, nuts, and fender washers.
By roll i mean rebound from a turn
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
