Disconnecting downpipe?
Mytrn2brn
145
Mar 11, 2006
buffalo, New York
Sorry guys dumb question. There is only two nuts holding the downplpe to the exhaust manifold right? This clap isn't holding anything is it?
Thanks
There are three bolts to disconnect it. Those two and one behind, took me a while to find it too LOL
Thanks
Just to clarify, on a turbo DSM, the downpipe doesn't bolt on to the exhaust manifold at all. The only time the downpipe would bolt to the manifold is on a non-turbo.
However, there are two studs holding the downpipe to the o2 sensor housing and 1 bolt holding the downpipe to a bracket on the front of the block on a stock setup. Most aftermarket downpipes eliminate the bolt that secures it to the block.
Hey thanks guys for the quick in info. Ok I just missed a bolt. Remove that an the dp will separate from the manifold. Don't worry about that clamp right?
Unbolt the dP forn the o2 housing yes..Then if it's stock, there should be a braket behind the Dp that holds it up..
If you have the manifold off which you probably don't..You should be able to see the braket behind the DP..
This is what the bracket that the downpipe bolts to looks like:
You do not have to remove the clamp.
  • Wanted 6 bolt NT water pipe
    • chrisman287
