Digital oil pressure gauge wiring
Dstratt01
42
Sep 1, 2012
New Haven, Indiana
Does anyone know if you can run an aftermarket digital oil pressure gauge through the stock oil pressure wiring or if you have to use the adapter and adapter plate for the oil filter?
Has to have its own wiring and its own sender
I got the sending unit installed and didnt even have to tap a new line in. It fit perfectly into the old sending unit port. Gotta run power lines still but after that I should know if everything worked out or not.
