Differential transfer case fluid
JacksTransmissions said:
DSM:
•Use Redline Lightweight Shockproof in t-case and rear diff. If you have an EVOIII rear diff, do NOT use Shockproof as the LSD will not work with it.
I agree with the above statement. I use heavyweight due to the fact my car sees mostly drag strip abuse and very little daily driving. For daily driving I'd stick with the lightweight.
Seeing as you are stock.... I would use diaqueen in the trans, and I'd use mitsu fluid for the tcase and rear diff, if your making power, heavy weight in the rear and t case, mt90+light weight shockproof in the trans, as per trevor from sheptrans. (I run this)
Jacks recommends NOT to use lightweight shock proof in the transmission usenet causes odd gear failures, light breaking a gear tooth. Use MT-90 in transmission and lightweight shockproof in transfercase and differentials.
