Difference between cams/CAS
cantgo2fast
188
Jul 2, 2009
Fort Collins, Colorado
Just got a set of frankenstein 274 degree cams. I incorrectly ordered them with the 90 CAS option and I have a 95. Since they didnt answer my phone calls or emails trying to get them to fix the problem ill ask here.
Is there a physical difference between camshafts that would lead to my 95 CAS getting the wrong signal from my new set of camshafts. For instance are there different slots, holes, teeth. I hope my question makes sense
You'll be fine. If you had a '97-'99 CAS on your motor then you'd have to drill/tap the intake cam to install the CAS correctly. The '95'-'96 CAS sits behind the intake cam gear and will work just fine if you accidently selected the '90 CAS option for those cams.
:dsm:
Thanks guys. I hope to have some driving impressions of these cams soon(ish). I havent seen many other people run these, if any should be interesting
Digging up an older thread...
You ever get your car running with the 274's? What do you think, hows the power? There must not be a lot of people running these cams. The search only brings up a few threads and none of them show any results just people asking about them.
