difference between 1G/2G head
shogun7g
30
Dec 15, 2004
St. Charles, Missouri
that's probably a common question here, but I'm driving a 95 Galant a with a 4G64 motor and I am doing the hybrid 63 head/64 block swap. I have a head in my posession right now, but how do i tell the difference? pics below:
steve
I concur with blackGSX2g, the size of the intake ports are smaller than that of a 1G.
awesome, thanks so much guys. ;)
steve
Which is the head that is supposed to be bronze on the inside? My gsx head when i pulled the Vc off was all bronze. When I pulled the VC off my 6 bolt swap talon, everything was definatley not bronze..How Do I tell the difference with the head on?Just from pulling off the Vc if possible...
Thanks
Bud
It was probably all "bronze" underneath the valve cover from the burnt oil residue.
A clean rebuilt head that was tanked and degreased will look like this with the valve cover removed:
Pennzoil does that to engine internals. Turns them colors from the nastyness that is that oil. Use valvoline or mobil 1 and you won't have that issue.
Since owning this car I have always used mostly valvoline, except for in the winter, which don't get driven much.....I have some Syntec waiting in the garage for summer..
