diff. between 90 and 91 motor?
pitbull419
981
Dec 31, 2004
port clinton, Ohio
i have been doing som research about the differences between the 90 and 91 cars.
like the brakes and rear end i belive(is this correct?).well i found a 90 laser with only 73 thousand original miles. the car is totaled but the engine and tranny are untouched and complete.well anyways i was wondering if there are any differences between the 90 and 91 turbo engines if so what are they?and are any of them on the block?
thanks
if you have the entire filter housing/cooler assembly, the 90 setup is better. Frankly, even with no cooler it's better, just to eliminate that source of coolant/oil mixture (potentially).
Obvious differences from the 90 motor that won't work with your 91 car are transistor pack, CAS, throttle body (maybe, can't remember). The vfaq should go more in depth, but the head/block/basics are all the same for all turbo six bolts.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
