diff between 90 and 91 6bolt block?
spidy3
192
4
Jan 20, 2005
upstate, New York
is there any difference between a 6 bolt block thats in a 90 TSi awd and a 91 TSi awd? I am planning on doing a rebuild in a month or so and i have a extra block out of a 90 Tsi. I am going to go with the 1g rod and 2g piston with total seal rings and clevite bearings. Will everything switch over just fine? So I have less down time with my car.
thanks,
:talon: Dom
the oil cooler housings filter housings are different as well. The 90 has a air oil cooler setup and the 91+ is water cooled. No biggie it should be an easy swap in that regards. Best of luck with the swap.
so everything from my 91 TSi will swap onto the 90 TSi block with no problems or kits needed correct? I just want to make sure before I get the 90 block out of the car. no difference in crankshafts or anything like that?
I know there are other differences like TB and engine wiring harness and stuff like that and the trans are a little diff. but I just need to make sure of the block cuz thats all I will be using.
Thanks,
:talon: Dom
