2G Did I break my GSX?
Look for stuff about white with pink dots vs white with light blue dots, then. The premium thing might not be the right label. I shouldn't have to hold your hand. Com'on, guys. Try. You can find the various DIFFERENT springs that have been put on 2G GSXs if you put in some effort.
And while you're poking around, be sure to notice how the VC in the rear works in the exactly the same way as the VC in the center. That might be something to know, too.
And finally, for Ss and Gs, do a global search for those Brembos. Don't stop until you find them, too.
Lmao.
Where to start.
YES, not all DSM's came with an LSD in the rear, however ALL CENTER DIFFERENTIALS are viscous, viscous means limited slip. Viscous is how ALL of our center differentials operate.
It takes some understanding of how our drivetrain components work. The center diffs in our cars use a silicone like heavy fluid as a medium and as soon as the (I don't know 17 plates?) start rotating at different speeds, the motion on the plates in the medium fluid will cause it to heat and become nearly solid because the viscosity of dilatant increases because of the heat. It's basically friction based. The fluid will then lock the plates together and transmit power from one set of plates to the other.
Viscous couplings are used as the center differential in some four-wheel-drive (4WD) vehicles such as the Toyota Celica GT-Four, and also as a limited slip differential (LSD) in rear axles. They offer a cheaper way to implement four-wheel-drive than technologies like the mechanical-transfer Torsen differentials used by Audis.
Difference in spring rates.
95-96 OEM Stock 2G AWD
Front: 265
Rear: 162 (+/- 8)
97-99 OEM Stock 2G AWD
Front: 246
Rear: 151
95-96 OEM Stock 2G FWD
Front: 246
Rear: 173
97-99 OEM Stock 2G FWD
Front: 246
Rear: 151
