DGI Chassis Tie Bar
I have had this bar for a few months now and figured I would give a review.
Install:
Super easy. Took me all of 20 minutes to do it. You basically pop off the plastic cover over the seat belt bolt and remove the bolt. Then put the end brackets in and bolt it down. Finally, you put the bar itself on with bolts/nuts.
Performance:
I have both RRE front bars as well as RMDSM sway bars. Before the DGI bar I could *feel* the back of the car being a little sloppy compaired to the nice stiff feeling the front had. The rear of the car felt like it would twist on hard cornering and didn't feel attached to the ground very well. After the DGI bar went in the car felt MUCH different. Way more tied down and more predictable as well. I can even tell the car is creaking less going into driveways and such. I spend a lot of my time hauling ass over mountain passes and this bar has really made it more fun.
Other:
The construction of the bar is really top notch. No Ebay crap here. The bar and all the hardware (brackets, bolts, etc.) are super bomber. Once the bar is in you can literally move the car by grabbing the bar before it will flex. You can also preload the bar by twisting forward or backwards once it's installed. If they end up getting the full Chassis Strengthening setup made for our cars I will be the first in line to get it.
The customer service is also great as you would expect from a shop that makes great parts like this.
Here is a link to the site: http://www.dgiautomotive.com/
Any questions?
