delphi 1000cc's good or bad?
WILOWNU
132
Mar 9, 2006
Wheelersburg, Ohio
I am looking to upgrade my fuel injectors. I am currently running 880's but i am getting a new tune this spring and gonna shoot for higher numbers. As I was browsing the net for a good deal I cam across the delphi low impedance peak and hold 1000cc injectors.
Delphi 95lb (1000cc) Low-Impedance Fuel Injector: CTS Turbo
just wondering if anyone has anything to say about these injectors... not a bad deal for 4 of them at 260 bucks.
They work just fine. PTE sold those for several years, and I have never had an issue with mine since 2005 when purchased.
My FIC 1000cc injectors look IDENTICAL to that picture. Mine have been fine for several years now, too. They flow a right at 100cc (global setting -55% on dsmlink). High fuel trim bounces at ±1.5%. My deadtime ended up being 360ms over.
One thing to make sure you do with this style of injector is to make sure you run the OEM o rings on them instead of running the ones that come on the injectors. the OEM are squared instead of circular so running the circular ones can sometimes cause major air leaks.
