Dejon Tool w/ Gm maf, CC in the way
1gDSMike
94
Nov 21, 2008
Portland, Oregon
I just installed my dejon tool upper intercooler pipe with 3inch gm maf, but my cruise control (90) is where the abs would be on newer years, at first i just put it under and it made the pedal harder but no problems then i did a WOT pull and it got stuck floor board and hit rev limit on the freeway! Ahh, so I unbolted the farthest right bolt on the cc and ran the cable over the gm maf, is there any other fix other than non cruise cable?? :confused:
You could always ditch that pipe and make a custom unit that will work for your application. Itll probably be cheaper than that overpriced dejon piece of scrap.
  • Wanted 6 bolt NT water pipe
    • chrisman287
