Deciding on a displacement..
Absit
2,390
43
Dec 19, 2002
Davenport, Iowa
I know it's been covered, and I've been reading a lot, but the forums are notorious for half finished threads that don't get resolved so here's what I'm looking at.
I want to run a max of 600 AWHP on my 98 auto with a 6/7 blade HX(super)40 on E85 tuned with ECUFlash. I did the math and found out I need 1600cc injectors and 2 fuel pumps and all that good stuff. I'll have a seperate tune for gasoline in case I can't find E85 at some point. I will be sticking with 7 bolt until I have a reason not to.
My initial plan was to build a 2.3 stroker with a 4G64 crank, but since I'll be replacing the rods and pistons anyway, why not just go with a straight 4G64 w/4G63 head? It's only a little more expensive but gives you better angles and whatnot.
I love torque, the car's going to be a daily driver and cone killer, not much into the drag racing. I guess my main curiousity is how does a 4G64 with forged rods/pistons (purpose built for 4G63 head) hold up versus a 4G63 with 4G64 crank with rods/pistons (stroker of course)? At that point the only thing really different is the block. Assuming equal builds, which one holds up to the test of time and daily use?
The difference between a stock 4G64 and a 2.3L stroker is the location of the wrist pin in the piston. All of the angles and velocity profiles are the same.
If you go to the trouble of putting a 4G64 block in you can use stroker pistons and longer rods to improve the rod ratio.
If I use a 64 block I wouldn't be stroking it, just sticking with 2.4L. Isn't the rod ratio already better in the 2.4 than the 2.3?
edit: I should ad, in case anyone doesn't know, to hit my numbers I'll be between 30 and 40 pounds of boost.
The 2.3L stroker has a 100mm stroke and 150mm rods.
The 2.4 stock has a 100mm stroke and 150mm rods.
The rod lengths and the stroke are the same. The rod ratios are the same.
However if you use pistons intended for a 2.3L stroker and 156mm rods in the 4G64 block you will have a slightly improved rod ratio. See the chart at http://www.dsmtuners.com/forums/str...acement-various-combinations-bore-stroke.html.
The RPM value at the right of that chart is the RPM where the engine has the same peak piston acceleration as the stock 2.0L at 8000 RPM.
Ah, I'm tracking now. Either way I planned to use stock length rods with the 64 or stroked 63. I'm not looking for high revs, just the opposite actually.
I'm in the same boat as you, only im planning on the 7 blade hx35 and shooting for 500hp. I've done a bunch of research and I have decided on the srtroked 4g63. Seems to be very reliable and will definatly suit your needs.
I'm leaning more toward the 4G64. When searching, this site seems to say I can only use one from a 93-98 Galant or DSM, but it seems like the following vehicles also came with the 4G64, why can't I use any of these?
93-98 Galant
95-99 DSM
93-94 Colt
93-96 Summit
97-99 Montero
93-96 Expo
