Decel noise after rear diff bushing install
mattp_65
Supporting Member
528
187
Aug 16, 2004
Granite Falls, Washington
Hello All,
Just need a little confirmation. I am assuming its all drive train noise with all I have installed. So recently I just installed rear diff bushings (Delrin not alum) and now the rear end area is making a loud noise only on Decel and in gear, but no noise while accelerating or not in gear (coasting). I still have stock oem front and rear subframe bushings (changing those out later).
I do have a built jack trans with ACT2600 6-puck solid (chatter of course), poly motor mounts n sway bar bushings, Torque solutions carrier bearing support bushings (Delrin), Energy Suspension rear bushing kit (poly).
Also I have the spare tire delete, so sounds are really amplified.
Carrier bearings are still in good condition, but I dont know about the u-joints.
Whats your thoughts?
