data logg with laptop
I thought that I replied in your other thread already. Anyway, the only two "user-friendly" laptop datalogging software that come to mind are:
Hand Held Halo's Hybrid OBDII software
EvoScan v2.6
I have both of these on my laptops and they work great.
if i use that one how good will it work with my 95 eprom ecu. i read that u can not logg more then 2 items at a time. also that they logg slower on 95 then 97+ ecu's.will that be bad when i try to tune my maft. if its slower will i have a crapy tune.
about the only thing that works well for logging a 95 with a laptop is ECMlink. unless you want to pull out the factory ecu and install a megasquirt or 98-99 ecu. if you are planing on sticking with the 95 ecu is to get the cheapest logging cable you can find, there really is no point what so ever for you to get the openport 2.0 adapter unless you are getting the 98-99 ecu.
yep cheep like this one only you are correct you will probably only be able to log 1 or 2 things at a time with the 95 ecu.
yep jst picked up this kit from dsmchips. Logs great on my 97 ECU.
DSMChips.com | DSM ECU Chips Enchanced by Keydiver
should be able to get away with a palm logger then. the only thing you cant log with the palm as far as i know if knock. i would sell you mine but i am not entirely sure it works anymore. i know the palm doesn't sync to the PC right now but i guess the cables and adapter should be good.
is it possible to log on laptop with 1g??
Yes, it is very possible. I can transfer my Scanmaster 3 + HHH-equipped laptop to another 1G DSM or 3/S and begin logging in no time.
  • Wanted 6 bolt NT water pipe
    • chrisman287
