2G dash lights no work-o
jerrylarsen
147
5
Nov 23, 2014
arvada, Colorado
so none of my dash lights work,they would flicker and if i messed with the dimmer switch they would come back on, then about a week ago i hit a bump on the highway and they turned off and never came back, so i thought thee dimmer switch went out, so i went to just bypass it, and they still are out, so now what do i do?im not sure what fuse is the dash lights (no panel cover) but i pulled all of them (in the drivers kick panel) and they all are good.. any help would be great! i dont like not having my running lights at night
By bypassing it did you remove it and jumper the black-yellow to the black (or to a real ground if that doesn't work)?
The fuse is the "Tail Lamp" fuse in engine fusebox.
If you did both of these, wiggle the wires near the connectors and check connector pins for corrosion and pins that aren't locking.
I did the first step, but I didn't check the tail lamp fuse, I will tonight thanks
