Dash is making sounds...
Onnipotente
105
Oct 16, 2003
Whenever i turn on the heat at any level, a vibrate or very fast ticking sound comes from somewhere in the dash by like the glovebox/airbag area. Does anyone have or know how to fix this problem?
dude i have the same problem except mine sounds more like a very faint crackling noise...and mine only happens when i put the heat through main vents that point at your face...
Is your airbag oscillating? You might try stuffing some same color weather-stripping around it.
It does that as well on my 92. I think its just dry-rotted debris getting blown around in the ducts...but can't get out. Mine only does it on full fan
the sound is gettin worse and worse... it sounds like the motor that is blowing the air is going to blow up soon... :|
