dsmgreddy
- 53
- 0
- Oct 22, 2004
Muncie,
Indiana
This has been a nightmare in the making. After pulling my head off...changing the HG and putting in new ARP headstuds, plus new water pump, all new gaskets, revised lifters, timing belt, new thermostat, prothane motor mounts, and new CAS (6 bolt).
I still have a no start. My brand new injectors aren't pulsing! I check the resistance and the injectors are good, but my resistor box was bad, or so I thought. I replace that box with a new one and still no pulse. I check and recheck the wiring, and I can't find a short or break. I just had my ecu checked out and worked on at ecmlink so I am farely certain it is good. I doubt it is the MPI fuse because it all cut out on me while my car was overheating, thus the HG change...
I am about to pull the whole engine harness and rewire the whole damn car, unless anyone has any ideas?
Sent from my SPH-M900 using Tapatalk
