Damaged the hard hydraulic line to slave cylinder
dredman1
61
Nov 27, 2007
Trinidad & Tobago, South America
I did a search, but only saw solutions for 2G cars.
I changed my slave today, and I think I broke my hydraulic line just at the point the hard line screws into the banjo bolt on the slave. :sosad:
I saw the 2Gs have a complete replacement stainless steel braided clutch line that runs from the master cylinder directly to the slave. But nothing for the 1G.
Can this line also work for the 1Gs or are there similar lines for the 1G? If not, what's my solution to fixing this? Does anywhere sell this portion of the hard hydraulic line (between the rubber hose and the slave) for the 1Gs new? (I don't have access to any junkyards with DSMs where I live).
If not, is there a way for me to fix the hard line, and if so how do I do it??
Right now when I try to bleed the clutch, brake fluid leaks from the line right by the screw fitting...
You're very welcome. Bookmark that site. You will be going there very often. Call them too. They are VERY helpful.
James :dsm::talon::laser:
OK. The line should be delivered tomorrow!!! Trying to figure out now the best route to run it....
Want to make sure it doesn't come near any moving parts (pulleys or belts) obviously. Any suggestions from anyone who's done this on a 1G?
And how did you secure the line? Tie straps?
Just run it the same way the stock one goes. And along the way zip tie it. Don't forget to bleed the summbitch fully.
