Cylinders 1&4 problem
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
so cylinders 1&4 aren't firing in my car. I haven't figured out yet if it's the ignition coil, power transistor, or ecu. This problem started happening after i was racing boosting 21psi, and it happened right after i was going a high speed (155+) and happened right after i let off the gas. anybody think that one of these problems is more likely to be caused by this? Thanks
Well start with the basics. Check for fuel, then spark and work your way up from their. Most likely its probably a bad coil pack
If you search the forum, this comes up to help get you started.http://www.dsmtuners.com/forums/newbie-forum/247425-question-about-ignition-cylinders-4-1-not-firing.html
ya neither cylinder 1 or 4 are getting spark. and ya i hope its probably the coil pack i ordered one yesterday i just keep thinking it's gonna be the power transistor though:confused:
I have 5 of them if you need one!
