Cylinder #4 misfire, lose injector
Boosted98gsx
2,099
22
Oct 31, 2002
Houston, Texas
Car loses #4 after a misfire at an apparently random point in time while driving the car. Still have spark, but my #4 injector is not firing. I have swapped the injectors around, and #4 continues to not fire. I have replaced the injector plug, and it still ceases to fire randomly, always throwing a #4 misfire DTC. I will lose the cylinder until I turn the car off (completely removing the key) a couple times. What could it be?
Pertinent information
2g
95 ECU w/ DSMlink
6-bolt
1g head
OEM coils
FIC 1000's
Anything else you want to know is in this link
http://www.dsmregistry.com/details.php?car_id=21
Thats great to know my 2g isn't the only one that does this. LOL I don't LOSE the cylinder but I do randomly throw that DTC, always being #4. I haven't fixed my issue, nor have I tried really, but yours seems a bit worse since it continues to run on three cylinders until you restart the car.
Check the injector resistor pack with a multimeter, for cylinder #4 you'd measure between pin 6 & 3 for 5.5-6.5 ohms.
You might also check the wiring at the ECU, possibly a pushed pin at the harness or intermittent connection. Its the GRN/RED wire going to pin 15 of the ECU... 2g ECU pin out
**Moving to Bolt-On Tech**
:dsm:
Thank you Corey, will check this tonight.
Just checked the resistance, all of them are at 6.5-6.4 ohms. So it's not the resistor pack.
*edit*
ECU pinouts look fine too. Nothing was loose with a light tug.
Found the problem for why cyl 4 was cutting out. Turns out, it's an ECU "limp mode" when it detects a misfire to save the cat. However, why I am having cyl 4 specific misfires eludes me.
  • Wanted 6 bolt NT water pipe
    • chrisman287
