needacar87
- 0
- Jun 22, 2006
Platteville,
Wisconsin
Ok so over winter break i was about to do a new turbo setup to my talon, but before i order anything i wanted to check out the engine, so I did a compression test. Cyl 1 was 180 Cyl 2 was 180 CYL 3 was 90 and cyl 4 was 180. As you can see there a huge problem with cylinder 3. I was told it could be I have a bad cylinder or it can be something with my head. Also there is oil on the spark plug every time i check it. My question is what other test can i do besides tearing apart the engine to figure out what is the problem?
. But at least that will narrow down what is wrong.
