Cyclone mani torque specs
If I had to guess, I would expect 14-16 ft.-lbs., based on bolt size and component material. Would love to see some concrete evidence of the actual specs if anyone has them.
And is the oring on the shaft the same as the throttlebody oring? Would limeto replace that to.
No, I measured it when I took it apart mime (more like destroyed it that is). This are the measured from the only one I've got left after my little demo operation:
Shaft I.D. (Millimeter): 8
Bore O.D. (Millimeter): 14
W Width (Millimeter): 4
Only replacement I've found so far is from the company rocketseals part# 8X14X4-MOS/D , it should work from the look of it but I am not sure about the type of pressure it would hold for the specific application (given temperature, gas type etc.) so I haven't managed to order any so far. Phone or fax orders only, they do take small quantities orders.
