cv boot replacement
tstkl
3,889
74
Feb 10, 2005
SoCal, California
Ok, so I tore the cv boot on my 1990 eagle talon tsi awd. Passenger side front axle, inner cv boot. So I call mitsu to try and get a replacement, and they say, we need your vin number. GREAT, because since I own an EAGLE talon, they can't give me the #(*&(*&^%##($&(#&$ part number. They tell me, "you have to call the dodge dealership, and have them check for the part number using your vin, then call us back." so, being the retard I am, I try that. FAT lotta good that did, since the people at the local dodge dealership don't recognize eagle. So I go to about 4 kragens, and at each one Im told a different one has them in stock, and drive like a moron all around the bay. Finally I get to one and the guy tells me to try all the other ones I already tried, so I order one. "I'll call you when we get it, which should be on the 18th". fast forward to the 23rd, still no call, so I call them. Yeah, they've had it this whole time, I go pick it up, and its the WRONG boot. now I have to go return this, and ALL I WANT IS THE PART NUMBER.
can someone help me where caps failed misserably?
(lesson learned, if I don't know the part number, don't bother trying to get the part.)
I'll probably end up going through raxles
My suggestion during reading your post was to go thru raxles.com, but u got it.
If it were me, I'd head down to NAPA and drop $65 for a new cv shaft. In most cases, once the boot tears and you keep driving, dirt, rocks, and other road grime tend to build up inside the boost, causing excessive wear on the bearings. Replacing the boot and re-packing it with greese can pro-long the event of failure, but it will not "fix" the problem. And for only $65 for a new axle, you might as well just replace it. Just my .02 though.
call this mitsubishi dealer in L.A. (9517353500). i forgot the name of the dealership but thats the direct number to the parts department. no need for a vin number just tell them what you need. and if you tell them that you mod your dsm, theyll hook it up. i just bought my 1990 oil filter housing for 60 bucks today and mach v has it for like $82. ive purchased from them before, fast delivery, and they usually have everything in stock.. just call em, trust me
McQuay-Norris Inner CV Boot, Eagle Talon TSi AWD - Part Number 66-2941
If Kragen is anything like the Checker I work at, they should be able to get that. Have them do a PartsAmerica.com price-match for $14.99.
I almost always replace the whole axle. They aren't that expensive anymore and besides I don't like getting my nails dirty ;o)
Good Luck
yeah, I ripped the cv boot trying to rip the axle out of the tranny, Im not worried about the dirt that might have got in there, since Im going to clean it before I repack it with grease...
thanks for the 411 boxxy
Depending on the boot, I "may" have the one you are looking for brand new. Will let you know, and let me know which one. Pay shipping and it is yours.
Mike
front passenger inner cv boot on a 1990 eagle talon tsi awd.
I will take a look and send pics this afternoon after work to make sure I am sending the right one.
Mike
After market replacements are known to be very weak compared to the oem green axles. It is very very very simple to rebuild an axle if you can get the needle bearings (or if yours are still in great shape) and have a set of snap ring pliers handy.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
