dsm mad man
- 89
- 0
- Dec 3, 2004
marriottsville,
Maryland
shuld i cut my springs in my 90 talon tsi?
they bounce like crazy.. HONDAS.. :thumbdown :laugh::thumbdown i wouldnt do itdsm mad man said:yha dident think so, im just going to buy a kit. got any idea what would be the best for under $200 for a AWD?
jtmcinder said:Cutting stock springs:
Pro: cheap (free, if you already have a hacksaw or plasma cutter).
Cons: cut ends will rust and separation taper at the end is lost, so the spring might dig into the rubber isolator (since you should cut the upper end).
Non-issues (all supposed cons): hard to calculate new rate ... non-issue because it takes twenty second with a calculator to find the new rate; hard to determine in advance the amount of drop ... non-issue because it takes five minutes to solve the simultaneous equations to determine this in advance; springs not designed to be cut ... car wasn't designed to be lowered; etc.
If I were broke and had a stock suspension, I'd cut my springs. As it is, I like them full-length, since I rallycross in the winter on the stock suspension.
- Jtoby
jtmcinder said:If you're a fan of that theory, use a hacksaw.
- Jtoby
