Cut off the rear o2 sensor. Bad?
DSM-Talon-John
Banned Member
296
Sep 16, 2006
Cheney, Washington
While removing my stock exhaust i cut off the rear o2 sensor cause i read hear numerous times it didnt do anything. Will it end up causing any poblems, theres just wies there now.
No, there should not be besides a thrown cel, I believe you can buy the o2 elimator kit where it will not throw that cel by soddering the wires into it for the rear one.
would the cel bring on the check engine light? Mine hasnt came on aslo i havent been able to check with my logger because its currently not working
The rear sensor being inoperative on a 96+ car with OBDII computer system will throw a check engine light. It will in no way affect the performance to the vehicle. It is there to check the efficency of the catalytic converter. If you are not required to pass an emissions test were you live then you don't have to worry about it. If you want to fix it you can reattach the sensor. Another solution is to buy a O2 eliminator. It's a little box that will connect to your rear O2 sensor connector and "mimic" the signal the sensor would normally send. This will fool the computer to think everything is ok.
DSM-Talon-John said:
Will it end up causing any problems, theres just wires there now.
Ignoring any CEL issues you should disconnect the plug where the wires connect to the harness. There is a hot 12v wire, a low voltage signal wire and two grounds flapping in the breaze once you cur the sensor off. If it gets wet you could short the 12v to ground or worse feed 12v into the ECU input. Both cases are likely to cause ECU damage.
Steve
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
