Custom Intercooler piping
94Talon2
271
Aug 1, 2002
Edm,
I'm making my own Intercooling piping and I was wondering if I can use the rubber clamps from Home Depo which are used for plumming? They look the same as the clamps used on most kits.
Thanks.
it depends on how much boost u plan on running...
i ran 18lbs on mine and i blew 5 of them in a matter of an hour, LOL, i heard if your boosting lower then 15lbs then they will work just fine and you wont have any problems with thenm, but if u plan on running big boost then expect to pay 20 bucks per coupler so that u can hold that good amount of boost.
Coup D E'Tat said:
Napa Auto Parts sells 2.5" radiator hose, which holds surprisingly well.
those things will hold like 10000 psi.
so how will you be running 8psi?
