Custom Ducting.
DSM_Newblet
76
May 17, 2012
phoenix, Arizona
Need help with how exactly to do FMIC ducting on my 2g eclipse such as what materials to use and where to put it ect. ect.
I'm having an overheating issue and it only seems to happen when the front bumper of my car is on so was hoping this would fix it.
depends on whether you wanna do short route, or long route piping.
long route requires not cutting of the body, and uses the factory SMIC piping location, short route requires you to cut through the radiator supports, and is the shortest path from turbo, too FMIC, to intake manifold.
long route heads in the same direction as the stock intercooler would be and the short route would go under cold air intake instead
  • Wanted 6 bolt NT water pipe
    • chrisman287
