Cryo2 cooling system
Spaz5spd
197
Feb 8, 2012
Springfield, Massachusetts
Has/is anyone running this system on their vehicles?
Are the gains in HP worth the money?
http://www.weberracing.net/CryO2-Systems/c232/index.html
Cold intake charge temperature = more horsepower however the CryO2-Systems should generally be considered once you have run out of other mods that you can do. Unless you live in a super hot climate, you will see very little gain on a stock or modestly modified engine. On a well modified engine you will see much better gain by cooling the intake charge. Refilling the bottles is a hassle and can add up in cost over time. I would recommend you wait and persue all other possible mods first...
I agree. There are plenty of other ways to make more power with less hassle. I well designed intercooler setup is all you really need.
