ECMlink cruise and idle log
Shatterstar201
Nov 4, 2014
North Arlington, New Jersey
Need help with cruise and idle log, dsm gurus please chime in
97 eclipse gsx 5 speed, dw 200 fuel pump, dw 1000 cc injector, aeromotive AFPR, big evo 16 from extreme psi, ecm link v3 full with 95 ecu, ingresol ebc. speed density conversion. AEM UEGO wide band.
Your SD table is a disaster. Start completely over. Meaning put in a 'stock' table and don't edit it. If you have to add that much airflow, your fuel settings are wrong. You're using airflow settings on the table as fuel settings. Don't do that. I assure you, with your mods, the stock settings are very adequate and you should be looking elsewhere [fuel].
Your cruise log is just a settings capture.
