crower cam install
The intake cam will have a slot on the end of it where the cas would go if you were using it in a 1g.
Thats the thing. Both cams have slots in the end. Im told its because they use the same core for both cams. The only thing thats different is one has a big purple paint spot on one and the other doesnt. I bought them used as a set and part numbers check out and everything, Im just not positive which one is which.
