Critique my order
Dsm_
66
Mar 24, 2012
Apache junction, Arizona
I have a 95 eclipse gst, Burnt my clutch power shifting against an wrx. I won but at a cost LOL. Its okay though because the 6 puck I took out looked awful.
Heres my order ...
You don't need the OEM dowel pins. The ACT kit comes with them. Also I never had any issues the the fidanza flywheel, it was used also. But if your planning on running one on a dd, I would get the aluminium flywheel kit from FP. It protects against issues with the bolts digging into the metal.
For the clutch, I had a 2100 with a solid 6-puck on my dd. Zero issues. I ran just over 30k before I had to replace it.
I also 2nd the fork/pivot ball when your already in there.
Last is why do you have a VSS on the list for a clutch? Does your speedo not work?
K I will try to get them all in one, I am 6 5 and very muscular so yes LOL I just barely fit in my eclipse, 2nd like a noob I dropped the teanny without unplugging he vSS hence I broke it, 3rd did not know about the dowel pins but extras never hurt, 4th I have the fork and pivot ball already in :)
