1Quick99GST
- 49
- 0
- Oct 15, 2003
Pensacola,
POSSIBLE PROBLEM DIAGNOSIS - IF SO, MOVE PLEASE
Stock injectors, denso 190 FP, read profile for complete list of mods
I have had no issues with creep at all, until I recently installed my ported big 16G with 34mm flapper. The T25 would hold 16lbs perfectly. After I got the 16G installed, it would hold 10lbs (removed BC) until around 5k RPM or so, then it would shoot up to around 20lbs before I let off (once 22lbs on accident). I have read that the 02 housing needs to be ported or it will creep, so I bought an 02 housing eliminator with external dump. Now it holds 10lbs, until around 5500rpm, then it does the same thing - creeps (quickly) to 20ish until I let off.
Now my car sounds like shit when I get on it, AND it still won't hold. Should I even bother hooking up the BC again to 16lbs? What else could it be?? What can I do?? Thanks in advance!
