creaking from rear driver suspension
'96_Talon_TSi
882
Sep 24, 2003
West Bloomfield/K-zoo, Michigan
Sometimes when I get in or out of my car there is a creaking from the rear driver side suspension. I'm thinking its a worn bushing or something. Anything else it might be? I checked the shock for leakage, and there was none, so I don't think that's a problem. ANy idea what it might be?
does it happen when you bounce up on down on the rear bumper, if so have a friend look for the source of the squeek while you are doing it. i can be anything from a bushing needing lube to a ball joint or maybe even that rubber pad that sits on top of the strut spring may have came out,
  • Wanted 6 bolt NT water pipe
    • chrisman287
