crankwalk question
cedp
May 6, 2009
jerz, New Jersey
i tried searching for it and read countless articles but still cant find a definite answer to my question. which is if my 2g engine walks can i still reuse the transmission? i think i know the answer which is yes i can but i just want to make sure before i put in my new transmission. thank you
Crankwalk is premature thrust wear inside the motor, nothing to do with your transmission. You will be fine re-using it.
yes you can still use your old tranny but you should consider upgrading some more parts while you're at it..like clutch, flywheel, throwout bering, fork, and pivotball. I made the mistake of not doing this at the same time and I had to drop down my tranny like 3 times. I've heard alot of stupid people say that if you rebuild the motor that it will damage your tranny or viseversa. this in my opinion is not true at all.
