Crankshaft Washer??
LKWTSI
601
10
Feb 7, 2008
Lake Wylie, South Carolina
I have checked my box of bags that had every nut and bolt I took off the engine as I stripped it down. I for some reason, don't recall the washer that goes between the front pulley bolt and the crankshaft. According to the DSM shop manual and the Haynes, there's a washer that goes between the bolt and the crank pulley. When I pulled the engine down, I can't remember now if it was there or not, my gut tells me it wasn't, but now I'm not sure. Can anyone throw any light on this? Here's a pic of my front pulley. The manual says it is supposed to be between the bolt and end of the crank.
Thanks for the replies.:thumb:
They very often do stick to the timing sprocket. Good thing you actually cared to ask the question and just didn't run it without knowing. If you don't install that the timing sprocket will walk off the crank and will cause all kinds of havoc.
HOLY Crap Batman:ohdamn:
Didn't even see itROFLROFL
Thanks guys. I'll go knock it off and clean it up.
