windsheild washer
so slow 420
110
Feb 18, 2015
Detroit, Michigan
so i replaced my nozzles on my hood cuz their wasent any when i bought the car so i replaced the hood nozzles and hoses.my washer fluid will not spray idn why the washer light is not on in the car so thats a good thing i dont hear the pump kicking in but if that was bad i would assume that the light would show up inside the car let me no what u all think the problem is thanks 2g non turbo
The sprayer motor being bad will not illuminate the washer light. The light is only a low fluid level indicator. You may have a bad sprayer motor, or a clogged line. Look around for leaks, or you can apply direct power to the sprayer motor to see if it comes to life. I recommend removing the washer bottle from your car first so it's easier.
