Crankshaft Sproket..HELP!!!ASAP
Z_no
Jan 10, 2010
Green Forest, Arkansas
So ive been doing my timing belt job, and I had a few problems if you wish you can look for my posts and youll get the story. Ive removed my crankshaft sproket and my guess is that its supposed to have a metallic seal on the back of it..if so that resolves my problem on my other tread....my problem now is ....if it has the seal under where do I look for it?? Ive been to autozone and Oreilley's and the want to sell me the plastic seal..the crankshaft one that goes between the blosk and the sproket....but I am looking for the metallic one that goes between the sproket and that plastic seal...i dont know if it has one..so I am only asking anyone out here...Thanks
on both my cars they did not have any seal be hind the sprocket and the oil pump other than the front seal
and if it did i don't think it would be a seal as more of a spacer or a belt guide.
Thanks, I believe that those metal parts that I found came from above the engine, my timing cover wasnt complete, so there is the wild posibility that it just fell and messed up my whole timing.
